Since your new truck will have new ring gears, use the proper procedure for breaking in new gears and new differentials.
That is, drive 15 miles, let the whole thing cool down. Then drive some more miles, allow to cool down. This way the gear is heated and cooled properly.
Once you get to 500 miles, you can start to subject it to more abuse.
But yes, change the oil as soon as you can - 1000 miles if you must. For towing, use Redline 80W-140 from the start. It has a break-in additive and is formulated fro use in limited slip differentials. The synthetic will NOT break down from the excessive heating that takes place w/ breaking in new differentials and gears. Conventional oil, OTOH, can break down and cause more problems. I try not to work out the differential + gears from the start.
But for street driving, Redline 75w-90 is great.
For racing/towing, Redline 80W-140 is better.
Don't get the "NS" lubes, they do not have the limited slip additive or break-in additive. The LS additive is useful in reducing friction and heat even in non-clutch type LSDs such as a Torsen or TrueTrac. Heat reduction/friction reducition is important but for clutch based LSDs, use half of what the manuf recommends to obtain better lockup performance or just use a gear lube that's formulated for use in LSDs.
But if you want to use a 75W-90 or 80W-90 lube, check out Schaeffer's #267 Moly supreme gear lube. Its a synthetic 80W-90 blend but its specs SURPASS that of every other 75W-90 or 80W-90 on the market. Its closer to a 75W-140 or a 80W-140 than a 80W-90 in terms of its viscosity reading at 40C.
Its loaded with moly so you know its all good.
[ January 16, 2003, 02:22 PM: Message edited by: metroplex ]
