My neighbor drives for Swift and is on the road for weeks at a time. For about 5-7 days every month last winter when he was home the darn tractor would startup on it own every in cold weather and run at fast idle for a long time (24/7). The colder it was the more it would start and the longer it would run. I think he has a KW but told me this spring the truck was going to be replaced. Looked new but had over 500,000 miles on it.
I am glad they moved so I won't have to listen to that next winter.
Those ice road trucks don't shut because it may never start again and they can't afford that. The rig will freeze up, the fuel will gel.
When I worked at the DOT, our 2-1/2 ton winter plow trucks took a beating and every winter several IH diesels would blow up. Seen it many times, 3 trucks down at the same time and a snow storm hits. Hauling a full load of salt/sand, plowing the road, freezing cold took its toll on many of them. The mechanic once told me in the 10-15 life of the trucks, everyone will see a new engine and maybe more before the are replaced.
All the oil came from low bidders. I seen drums from Mobil, Citgo, Marathon in the shop. Oil was oil, only thing the cared about was saving the budget and put off anything till tomorrow.
