Actually, pure D2 diesel has in fact more lubricity then MMO or Lucas, here is the study:
http://www.dieselplace.com/forum/showthread.php?t=177728
From the above link:
Quote:
1) 2% REG SoyPower biodiesel
HFRR 221, 415 micron improvement.
50:1 ratio of baseline fuel to 100% biodiesel
66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel
Price: market value
14)Lucas Upper Cylinder Lubricant
Gas or diesel
HFRR 641,
5 microns worse than baseline (statistically insignificant change)
427:1 ratio
7.8 oz/tank
$2.65/tank
17)Marvel Mystery Oil
Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems)
HFRR 678,
42 microns worse than baseline fuel.
320:1 ratio
10.4 oz/tank
$3.22/tank
Lucas did slightly better than MMO so it's not just hype and marketing.
B100 biodiesel fuel is the best upper cylinder lube you can find, but this is for diesel engines, in gasoline engine MMO or Lucas will do just fine.
