Ford F550 with 6.0 Navistar turbo diesel
I am in Bolivia. My truck is dead. Died with lack of power, first thinking it was a fuel problem. I had it towed 120 miles to town. 3 "experts" have examined it. The first said the computer was shot after scanning it with a Snap-on scanner and getting different codes. He had it running once, then could not get it running again. He tried cycling the injectors and it stopped after 3.
Towed to the Ford shop (they have never seen an F550 or a 6.0) They connected the ford scanner and got nothing. no signal. no power. They say I need a new PCM.
A friend who has worked for Toyota and Nissan in Japan went over it and says he does not believe it is the PCM. There is no positive or negative at the main computer (International). The check engine light stays on even when you take out the computer and PCM. He says there has to be a short to send power to the check engine light.
I do not want to buy a PCM or computer if it is not bad. Nor do I want to buy one and put it in if there is a short or something that might have caused one to go bad.
When you turn the key the injectors start making noises.
First question: does the power go from the PCM to the computer or from the computer to the PCM?
Second: is he right that the check engine light should go off when you disconnect the computers?
Any other suggestions?
I've been asking on thedieselstop, but no answer yet.
