Are there any readily available dies that I can add to my brake fluid to change its color? When I do a flush I can't tell when the old fluid is out and the new fluid is in. I would like to add some die to new brake fluid, flush the system until the colored fluid comes out of the calipers, then the next time I flush I will use brake fluid without die and flush until it is clear.
Or is there a Dot3/4 brake fluid that is a different color than normal brake fluid?
