I have a natural gas powered 4.3L Chevy engine serving as a power unit for an irrigation well.
It is equipped with a sight gauge for checking oil level while the engine is still running. If we change the oil and fill the engine to the full mark on the dipstick the oil wil become foamy and make checking the oil level with the sight gauge impossible. As a result we intentionally run the oil level lower than the dipstick says is OK. We have probably put ~10,000 on this engine using this method over the last 6 or 7 years since we installed it new.
It uses very little oil. Occasionally we overfill it and it makes the sight tube harder to read every time because some of the foam residue stays in the sight tube. Since it's tough to see and doesn't use much if any oil (I thought) we don't try very hard to check the oil level between oil changes (once every 168 hours before this year, this year I decided to switch to 336 hour intervals).
The engine shut down today at about 272 hours since the last oil change. As an looked it over I noticed that the oil level was VERY low, lower than I have ever seen it by far. I put some more oil in and tried to fire it up. It would not start. It has spark. I assume it has fuel and air although I'm not an expert at checking fuel on a natural gas engine.
The engine is equipped with a Murphy switch which is supposed to shut the engine down anytime the oil pressure gets low or the engine temp gets high so I would think even if it ran out of oil it would not do catestrophic damage but it would not start and it was exceptionally low on oil which seems pretty coincidental.
Tomorrow morning I guess I will go verify fuel and air and then check compression and timing.
Let's assume the Murphy switch worked correctly. Is it possible low oil levels that were still allowing for the oil pump to pick oil up to maintain oil pressure could cause me to ruin my compression rings? I tend to believe if I have compression I'm not in bad shape and I'll surely be able to get it running but perhaps there may be some other oil related problem I'm not thinking of?
Any thoughts on other things I should check tomorrow? I appreciate it, thanks.
