Temps reached a balmy 22 degrees F today so out came the Chevron Supreme 5w-30 and in went to Havoline Synthetic 5w-30 and new motorcraft filter. Problem is in my rush to get done as quickly as possible, I forgot to collect the draining oil when I pulled the plug (I did remember to go for a 15 mintue drive to heat things up). By the time I started collecting drain oil it was almost at a trickle. I got about 1/4 of the Blackstone sample bottle filled before it all but stopped. The remainder of the sample bottle was filled with oil I poured out of the Supertech filter.
Is this sample any good or should I just trash it? I really wanted to see how the Chev Sup did with the cold weather. The interval is around 4600 miles.
Boy do I need to build that heated garage!
Mikep
Mikep
