A 20wt oil falls between 5.6-9.3cst. Most ATFs are blended in the ~7-7.5 range. Some of the higher mileage ATFs hit up to 8.5cst. And, I've seen some racing ATFs that are 30wts in the 10cst range. Does this mean that regular ATF is presheared high mileage ATF? or seriously sheared racing ATF?
So, DexronVI is NOT presheared. It, like WS and SP, are blended to 6.0cst using higher quality basestocks and additives that maintain that viscosity over a longer period of time.
So what is better, a DexronIII 7.5cst fluid that shears to 5.8 in 10k miles? Or, a 6.0cst ATF that shears to 5.8 in 10k miles?
At 30k, 60k, 100k the numbers will show the true quality of both fluids.
And, what are the side effects of excessive ATF shearing of the thicker ATFs? additive breakdown? varnish and crud buildup? increased oxidation? Mineral DexronIII just doesn't look so good any more.
So, blending to a different viscosity is NOT presheared down. Thats some ignorant thinking. 5w20 is not sheared down 5w30 oil. And, 75w85 is not sheared down 75w90 gear oil.
I think that DexronVI is a step in the right direction. But, so was MerconV and ATF+4, and a bunch of other blended or full synthetic ATFs. GM is a little slow!
