My wife drives an '01 Caddy Deville DHS that recently had the transmission replaced under an extended warranty (good experience BTW), I had been doing drain and refill with Valvoline Mercon V since that fluid also met the old Dex III spec from when the trans was new. The dealer put in a used transmission and flushed/refilled it with Dex IV. Can I still do my maintenance with the Valvoline Merc V? My Jagaur also uses this fluid so it means I only ahve to have one fluid on hand. Are Dex IV and Merc V incompatible in this since or is it "OK" since they both meet the old Dex III spec?
