Detroit S60 / Rotella T 15W40 / 22500 miles
Decatur AL USA
2005 Detroit Series 60 14.0L EGR 515 bhp / 1650 Torque
Avg. 7.5 mpg. Idle percentage under 10%.
Oil Capacity is 10 gallons (1 gallon remains in cooler during change).
Shell Rotella T Triple Protection 15W40 CJ4 with 60 days and 22,500 miles. The add pack in this looks more like T5 or T6 than the old T3.
Any objections to stretching this on out to 25,000 miles?
34 - Iron
1 - Chromium
0 - Nickel
2 - Aluminum
0 - Copper
2 - Lead
0 - Tin
0 - Cadmium
0 - Silver
0 - Vanadium
3 - Silicon
2 - Sodium
3 - Potassium
0 - Titanium
46 - Molybdenum
0 - Antimony
0 - Manganese
0 - Lithium
12 - Boron
1064 - Magnesium
1088 - Calcium
1 - Barium
1106 - Phosphorous
1360 - Zinc
0.7 - Soot % Vol
14.4 - Viscosity 100 °C cSt
5.26 - Base Number mg KOH/g (D4739)
12 - Oxidation abs/cm
19 - Nitration abs/cm
Sample #1
18-Jul-2011 Date Sampled
27-Jul-2011 Date Received
28-Jul-2011 Date Tested
60 Days / 22,500 miles - Lube Time
519,388 miles (Odometer / Actual is 606,908) - Unit Time
Yes - Lube Change
1 gallon - Lube Added
Yes - Oil Filters Changed
Low fuel, low soot, half TBN still left. Visco is the only possible concern. Has it sheared? Could run to 30K miles. Maybe more if visco remains good.
Shell spec says 15.5 cSt. In the real world it seems to be closer to 14.9-15.2 cSt. The oil is down to 14.4 cSt so it seems to be holding up pretty well.
Originally Posted By: Doug Hillary
Hi,
Gene K - I for one commented on this in your previous Thread?
Thanks Doug. I somehow overlooked your response.
I think your report looks excellent. 30k should be within reach with this combination. Either run it right to 30k and sample, or take another sample along the way.
Edit: I just noticed that this oil was changed at the time of the sample. Pity, I think you could have run it to 30k easily.
Thanks Roy. I will likely put on 30,000 miles in the next 60-90 days so we wont have to wait long. I guess I should stop procrastinating and add a sample valve but their is a heavy bracket on the EGR engines that blocks the normal location so I need to remove and drill that for access.
