Following on from my troubles with our VW T5
HERE (worth a look if you like blocked oil pick ups from excessive RTV use), I'm currently looking to determine if any serious wear to the engine bearings has occurred.
To confirm, before my strip down, the engine operated perfectly with no abnormal noises. The only reason for the strip down is due to random and intermittent oil pressure lights.
The engine has had an undocumented rebuild at some point in the past, and still uses standard size bearings.
The crank is perfectly smooth with no scratches that can be felt with a nail or anything untoward.
The lower cap bearing seems to have lost it's initial coating in places, but again, is totally smooth with nothing I can feel with my finger nail.
And exactly the same for the upper bearing. Slight coating loss, some scratches but nothing I can feel with a finger nail.
How do I determine if these need to be replaced? I've done some googling and haven't come up with much.
