Does conventional oils (Motorcraft or Havoline) meet the detergency levels of Mobil 1 Synthetic?
Which conventional oil has the highest level of detergency?
Does a used oil analysis track the presence (or lack) of the chemical used as a detergent ? Could someone please exlain what this chemical is ?quote:
This is actually kind of a tough question to answer, as we would want to compare TBN for PCMO's and not all product data sheets list this info.quote:
Great thread on detergents. Thanks Steve S.quote:
Originally posted by Steve S:
texasproud , Molakule has excellent additive posts in question of the day
You're absolutely right about the importance of base oils' contribution to finished motor oil formulation. For those who believe otherwise, it's not mere coincidence that SM 5W-20 through 10w30 motor oils have abandoned Group I base stocks. But, the old "sweet" and "sour" unofficial designations were reserved for crude petroleum, not refined base oils. Even at that, those terms are effectively obsolete in this era of Group II, Group II+, and Group III hydrocracked base oils. Refiners can (and do) generate very high quality Group III base oils from the crappiest grades of crude - all it takes is sufficient energy and time in the hydrocracker.quote:
Originally posted by Robbie Alexander:
base oil does play a big role as some are sweet and others are sour...
I'm guessing that Calcium Carbonate (shows up as Ca) is one detergent, along with Zn (which may also be an Anti-Wear), P, Mo, Mg, and Sb.quote:
