Actually it's gone down because most asteroids of that size have been mapped and we should be good for the next few hundred years.I'm sure that was the chance 65.999.999 years ago, but every year since the chance has gone up...
The only thing close to that would be if the false vacuum theory is true. Then the entire universe would disappear into the true vacuum and it'd happen at the speed of light so you wouldn't even know that it happened til it happened. Fortunately it's unlikely as the universe was at a higher energy state during cosmic inflation and it were to happen it would have happened then.My main concern would be a nuclear blast fracturing the Phantom Zone and releasing the three Kryptonian villains
This messing around with Apophis is very suspect. NASA has been adamant for months that the astroid is not a risk to earth impact in 2029, but why would they go to such massive expense to alter the trajectory? And what if this attempt, back-fires and it actually 'moves' closer to Earth and get's sucked in by gravity?
I think Apophis is truly a threat and NASA is lying to us.
Here's a prophetic, biblical angle......
The Dart is supposed to hit today.Hey what a coincidence. Apparently there is a launch next month to test the concept of striking an asteroid with a missile. This is from the Washington post.
True, Al… And if it’s higher than that, well, you won’t really feel it anyways when that impact comes.Since the last earth killing asteroid occurred 66 million years ago...the odds of one hitting in the next 50 years are exactly .00000001% or .0000000%. at MOST. Sleep well.
Right. The further away, the smaller the nudge needs to be."This study doesn’t change the fact that kinetic impacts are preferred when it comes to asteroid deflection. The further away an asteroid is when it’s detected, the better. A smaller kinetic impactor is enough. But this study is aimed at late-time small bodies. There isn’t enough time to launch a kinetic impactor with enough mass if we don’t have enough lead time."
The conjecture of the destructive meteor theory has been disputed recently by a number of scientists.
The degree to which extinction was caused by a meteor has been argued, but the iridium layer is incontrovertible, as is the crater. Earth was hit.The conjecture of the destructive meteor theory has been disputed recently by a number of scientists.
Saw news story where NASA showed that the spacecraft hit the moonlet, not the main asteroid.Here is a shot about 10 minutes earlier when the camera on the spacecraft showed both the asteroid and the moonlet orbiting it. It then zoomed past the asteroid and hit the moonlet. Amazing.
