Denso Spark plugs.
Kentucky
Does anyone know how to interpret the part number for Denso spark plugs? I picked up a set for the truck that I just sold and I'm wondering if I can use them on my current vehicle.
The spark plugs are the new Platinum TT plugs with #PK16TT written on the insulator. The box has PK16TT 4503 written on one end.
My current vehicle ('00 Kia Sportage) requires PK20TT 4504 plugs. Is this just a different heat range? The listed specs are all the same (5/8, same thread pitch, gap, etc). Is it safe to use these plugs?
PK16TT
http://www.sparkplugs.com/results_cross.asp?pid=PK16TT&x=0&y=0
Platinum TT Plug, 14mm Thread Size, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Solid Terminal Nut, Platinum Alloy 1.1mm Fine Wire Center Electrode, Titanium Enhanced 1.5mm Fine Wire Ground Electrode, .040" (1.02mm) Gap, Heat Range 16
Recommended for 2005 Kia Sportage
PK20TT
http://www.sparkplugs.com/more_info.asp?AAIA=&pid=41630
Platinum TT Plug, 14mm Thread Size, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Solid Terminal Nut, Platinum Alloy 1.1mm Fine Wire Center Electrode, Titanium Enhanced 1.5mm Fine Wire Ground Electrode, .040" (1.02mm) Gap, Heat Range 20
Recommended for 1998+ I4 Kia Sportage
