I'm also interested in the difference with the new Delo 400LE.
FYI, this was taken from the caltex website.
This seems to be the difference between the 'older' Delo 400 Multigrade and the 'newer' Delo 400 LE
KEY PROPERTIES
.....................Delo 400 Multigrade ...Delo 400 LE
SAE Grade.......................15W-40 ...15W-40
Density at 15°C, kg/L............0.886 ...0.886
Base No., D2896, mg KOH/g.....12.2 ...9.6
Base No., D4739, mg KOH/g.....10.0 ...N/app
Sulfated Ash, %m..................1.4 ...1.0
Flash Point °C......................230 ...204
Pour Point °C....................-33 ...-30
Viscosity, cSt at 40°C............125 ...125
Viscosity, cst at 100°C...........15.1 ...15.7
Viscosity Index...................125 ...131
Zinc, %m..........................0.15 ...0.13
Delo 400 Multigrade:
PEREFORMANCE CHARACTERISTICS
• API CI-4 PLUS, CI-4, CH-4, CG-4, CF-4, CF, CD
• API SL, SJ, SH
• ACEA E7-04, E5-02, E3-96.
• JASO DH-1
• EMA Global DHD-1
• Caterpillar ECF-2, ECF-1a
• Cummins CES 20078, 20077, 20076, 20072
• DDC 93K214
• Mack EO-N Premium Plus 03, EO-M Plus, EO-M, EO-L Plus
• Volvo VDS-3, VDS-2
• Mercedes-Benz 228.3
• MAN M 3275, 271
• MTU and DDC Categories 1&2
• ZF TE-ML 04C, 07C
Delo 400 LE
PERFORMANCE CHARACTERISTICS
Caltex Delo 400 LE SAE 15w40 meets:
• API CJ-4, CI-4 PLUS, CI-4, CH-4, CF, SM, SL
• ACEA European Service Categories E-7
• major diesel engine manufacturers' requirements
Caterpillar
Cummins
Detroit Diesel
MACK
Man
Mercedes
Volvo
• engine test performance requirements
• Caterpillar ECF-3, ECF-2
• Cummins CES 20081
• DDC Power Guard 93K218
• Mack EO-O Premium Plus 07
• MAN 3275
• Mercedes Benz 228.3
• Volvo VDS-4
So, am I right in saying that it looks like the 'older' Delo 400 multigrade seems to be a stouter oil than the newer Delo 400LE, however the new LE has less ash?
BTW, is sulfated ash an issue with motorbike motors, specifically newer fuel injected sportsbike motors?
Also, isn't higher zinc better for motorbike motors or am I just way off track???
Cheers,
Dan.
