Hey, all,
It's been 4 months and ~3200 miles since my last OC, and I'm all set to do the deed . . . but I can't!
Here's the problem. Since my car has a belly pan and is designed for oil extraction, and since I don't have anywhere to store ramps, etc., I use a Topsider to draw the oil out through the dipstick tube. On Sunday, I was all set up, but the Topsider's bicycle pump handle was sticking.
Instructions said to pop some oil down the tube to lube the leather seals. Unfortunately I used contact cleaner (idiote!
). That lubed the seals all right . . . to the point that the pump slides too easily, and I get almost no vacuum built in the tank.
I called AirPower America, who has parts. They have replacement pump tubes, $20 shipped. But they suggest I try relubing the seals with some oil first; it might solve the problem.
I can lube the pump tube tonight, but I can't test it on the car until this weekend. If it works, fine. If it doesn't, I'll have to wait for the new tube until the following week, and won't be able to do the oil change until the end of the month.
Can you say frustrating??!!??
Vent time over. But have any of you had a similar series of events that blocked/delayed your oil change session?
