Rear window was fogged up yesterday. Getting everything ready for a tint job.
Tested rear defrost and only 50% of the feature is working.
I have one contact on one side that needs to be re-attached, so this result in the picture is after me manually holding the contact in place. The one on the other side is still connected.
I have tested continuity from the main vertical strip across all lines and they all have continuity on both sides.
I have tested voltage to ground and all the horizontal lines have the same voltage to body ground.
I can feel some heat on the main side strips down to the area on the bottom where it is not working and then the strip is cool.
Nothing defogs just by having the one good side connected, but there is good voltage with just the one good side connected.
What else can I test for? I would like to have these working before tinting, but if not, it won't be the end of the world, but it does help clear rear window for better visibility on humid rainy days.
