With all this talk about timing chain stretch / failure in the Ford truck Ecoboost engines I have decided to bump up the oil strength and start using an A3 rated oil in my baby.
As of today it has Castrol 0W40 in it. My figuring is with all the fuel dilution going on in these (and other DI) engines, by the time 4k miles roll around it'll probably be a 20 weight oil when I change it.
It seems to me that oil dilution coupled with soot contamination is partly responsible for these failures. Mine is a 2011 with 79k miles and is quiet as a mouse on start up and I'm going to try to keep it that way.
On the Mazdaspeed forums many are using Rotella T6 in the Speed 3 cars with no problems whatsoever. That may be my next oil, the only reason I started out with the Castrol was the SN classification. T6 is SM, which my engine might not even notice if I were to try it.
Any comments / observations?
