D1G2 20wt oil HTHS for GM
ON, Canada eh?
Folks,
My aunt that had the Nissan Juke that puked the CVT transmission recently with only 90K, has gone out and bought a new GM vehicle, so I'm looking for a quality shelf-oil with the best HTHS that meets the dexos 1 Gen 2 specification.
She lives out of town from me so she will have her mechanic put in whatever I tell her is best.
As I use Amsoil and I'm not up on who would have the best HTHS in a 20wt that is dexos 1 Gen 2 approved from the shelf variety and I thought rather than try to look over all the PDS's and compare I thought it might make for good discussion here.
The reason I'm concerned is because the vehicle is under warranty and I want the best protection she can get from a shelf oil to safeguard against timing chain issues.
What car is it that you think will have timing chain issues? Doesn't it just require a Dexos 1 or 2? I just run Mobil 1 in my Caprice and 2.0 Turbo Malibu. No issues.
Originally Posted by StevieC
..... best HTHS in a 20wt that is D1G2 .......safeguard against timing chain issues.
By "best" HTHS, are you really saying highest HTHS? HTHS is just a minimum specification. I've never seen one outside the small range of 2.6-2.7 in dexos1 Gen2 oils that is. Moly protects timing chains quite well according to some tech papers, & Zepro Eco Medalist 0w20 dexos1 is the highest moly dexos1 Gen2 for timing chains. Amazon best source for it.
I don't want to specify the vehicle because it will turn into a peeing match over which version of the engine has the issue and which one doesn't and that's not important.
The manual calls for a Dexos oil in the 20wt variety so I'm looking for a shelf oil that is D1G2 20wt that offers the best HTHS for her.
Yeah that's what I thought but I posed the question anyway in case there was one that was slightly higher. I will also be looking at Moly content and preferably the Tri-nuclear type.
Just tell her to either get M1 or Pennzoil Platinum and I'm sure that engine will live a long life with either.
I'm sure you are right but this it BITOG and it's about the extra margins.
Just check the oil manufacturer websites for their PDS. I think you will discover that they are all pretty much the same.
As I have said many times, any major brand will do.
PimTac, there is a reason I didn't do that. I specified that above
Also it's important to know others thoughts.
I'll give a hint here, most brands are 2.7. One brand is 2.75. I won't say which one.
Good luck.
Originally Posted by OVERKILL
No, but it probably does, being an XOM product.
I just tried looking it up on PQIA and the 5w30 looks like it has it but not sure about the 5w20. I would imagine it would being in the same series of oil.
Originally Posted by CT8
With the proper specs and a major brand name oil is oil.
I agree at this point in time it's more about brand preference.
I like Mobil 1 so what can I say? Mobil 1 5w-20 is SN(+), Dexos and GF5 at HTHS 2.75. Mobil 1 High Mileage 5w30 is SN, A1/B1 at HTHS 2.7. HM would be my choice for the ACEA certs. But that's pretty nit-picky on my part. Truthfully, ANY Dexos oil would do just fine...
The Ravenol DXG has tri-nuclear moly, dexos 1 Gen 2 approval, and is a shelf oil at Blauparts. Only thing is its a 5W30, but so far in my Fusion its as smooth as warm butter. Only real negative is the cost.
