From what I can see the clamp on my Toyota Highlander looks similar to Oetiker Clamps.I’ve been using Oetiker clamps for a while. Stainless steel ear clamps. One time use.
OEM on Volvos and very convenient for most places where you would use a hose clamp. They go on quickly, hold tight, don’t loosen and are cheap.
CV boot clamps are basically big Oetiker clamps.
So, Oetiker clamp pliers. Name brand are moderately expensive. Lots of knock offs out there, but I prefer good tools. I recommend the kind that have both the front and side clamp in the pliers. Particularly around CV boots, you might need the versatility.
Oetiker Reliable Connections
Oetiker is a global leader in high-end connecting solutions for the vehicle industry and for high-value applications in industrial segments.www.oetiker.com
They are, before buying make sure you have access from the bottom, if not get the angle ones. I have both and use them equally as much.From what I can see the clamp on my Toyota Highlander looks similar to Oetiker Clamps.
I bought these after Trav recommended them, and they worked very well.Lisle 30800
Also available in offset 30600 to get access from the side which is common with rack boots.
Amazon.com: Lisle 30600 Offset Boot Clamp Plier : Tools & Home Improvement
Buy Lisle 30600 Offset Boot Clamp Plier: Vise Grips & Locking Pliers - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Are you ordering these individually (From the dealer) when performing steering rack boot or inner tie rod replacements? Some OEM's do not list the clamp or clamp sizes in their catalog.I’ve been using Oetiker clamps for a while. Stainless steel ear clamps. One time use.
