Originally Posted By: 4WD
I've seen some good looking filters that would've looked even better if the person had just simply changed the oil out sooner. What's the point in running an OCI until you see black oil and gritty crud in the filter ? Is that supposed to be impressive ?
That … and when I started running the same filter on the same motor twice as long … (two OCI) you bet I cut it open to see how it held up … not allot of work and safe if you have a proper cutter …
In my view this is the next best way to see what may be happening in the engine without having to pull a valve cover. I think this brings value to the oil change. I cut every filter whether I post it or not. My oil change habits have improved greatly since doing it.
