Yet another repair needed on the Case IH 5120. We cannot go beyond approx. 1800 rpm without getting misfire. It only happens randomly. The engine never smokes black and I'm hoping it is a supply problem. A fuel filter change did not help. Next is a supply pump replacement, we're still waiting for an adapter to arravive.
In the meantime, I would like to remove the diaphragm on the VE-pump to access the fuel pin for a little lubrication.
What's safe to use in terms of seal compatibility? Does WD-40 swell seals?
What about petroleum jelly or a dedicated seal grease, such as Parker O-lube?
