Looking for a full-flow option on filters for my pickup..
I purchased an oil cap from these guys a while back and was very impressed with the build quality.. How does this filter compare to other full flow filters on the market?
P/N EPS-5900
Applications:
Dodge Cummins Turbo Diesel 5.9l
Designed For Longer
Service Intervals
OilGuard Full Flow Lube Oil Filters are designed for extended life duty cycles and provide the most efficient particle removal of any full flow filter on the market. OilGuard full flow filters will reduce engine wear, reduce operating costs and support long oil drain extensions (when used with the OilGuard Bypass Filter). OilGuard full flow filters remove particles at the 20-micron size at an efficiency of 98.7% (absolute) and at the 10 micron size at 50% (nominal).
From here: http://www.oilguard.com/Dodge.php?PHPSESSID=6df73d47065b29c7b4519d97ae4e9482
They cost $10 each..
P/N EPS-5900
Applications:
Designed For Longer
Service Intervals
