I've owned three Diesel's since 1985 with the current one being a 2003 Chevy Duramax 6.6L (which by no means makes me an expert). I have always used an additive starting with my shiny new 1985 VW Diesel. In the beginning, I used an additive (Power Service) to make me "feel good". I "believed" it was doing all the things the label said, like keeping my injectors clean, increasing cetane, (whatever that was), and keeping the fuel from "gelling" when it was cold out. Now, with the advent of the Internet (do a search on diesel fuel additives), I've learned there are some good reasons for using a diesel fuel additive. I've also discovered that there are a wide variety of opinions regarding additives including what type (water emulsifier vs water demulsifier), what brands, when to use or not to use. My personal conclusions and main reasons for using a diesel fuel additive are as follows:
1. Since Diesel Fuel WILL contain some amount of water and water is BAD for the injection pump and injectors, I use an additive that demulsifies water so the water separator can do it's job (and trap the water before it reaches the pump and injectors). GM has also taken the demulsifier position - see
http://service.gm.com/gmtechlink/images/issues/apr03/TLApr03e.html#story1 On the contrary, some very smart people believe it's best to "lock-up" and disperse the water with an emulsifing additive so it passes harmlessly through the system. This makes sense too. IMHO, either type (emulsifier or demulsifier) is better than none.
2. Since today's Diesel Fuel is low sulfur, it needs some added lubricity. Most additives contain lubricity enhancers. I also add a few ounces of tcw3 2-cycle oil at each fill-up as a pump and injector lubricant (since it's designed to burn with no ash).
3. Since I live in the North East, and untreated Diesel fuel will form wax crystals when ambient temperatures fall below 20degF, I use an additive that prevents wax formation (gelling). Winter, or all season, additives will also prevent the water in diesel fuel from freezing.
Flame suit on … all comments and criticism are welcome…
[ May 29, 2003, 07:50 AM: Message edited by: Bill Plock ]
