Crazy Belt Stuff
LI, NY
I put a new serpentine belt and idler/ tensioner pulleys on my Suburban yesterday. Truck has 116,000 miles on it and I have never changed the belt that drives the ac compressor. Decided it was time since I have a trip coming up.
I looked at the compressor and saw no way to adjust tension. I'd figure it out. I went to the store to get the parts. The counter guy brings the ac belt and says this is a stretch to fit belt. No tensioner.
I asked if there was a tool. There was and I purchased it also.
I watched a Youtube video and got to it. Cut the old ac belt off, slipped the new one onto the compressor and over the back of the crank pulley and inserted the tool between the belt and the pulley. Turned the engine with a ratchet and the new belt was installed. took about a minute.
I guess the OE's figured out a way to save a few bucks when building a new car.
Have the same "Fitted" A/C Belt on my '01 Camaro (2011 Camaro accessories)
I like the design, With all the A/C belt tensioning issues GM trucks had from '99-'07.
Not sure about trusting aftermarket belts with this configuration....
If you read the other thread posted above you can see that Steve says the tensioner for the old style A/C belt has problems because its mounted so low it gets water & debris in it.
So, I'd consider the stretch fit belt an improvement even though its a minor hassle to install it looks like.
Yeah... It's a 2009. The original belt lasted 116,000 miles and looks perfect. Really can't complain.
