Coyote + Track Time - Oil Choices
I recognize it's tamer. Part of my concern is that this engine does run hotter on oil, normally. 230F is a pretty common oil temp when commuting around town with zero aggressiveness. There's also some nuances to the oil temp calculation algorithm where ac on/off makes some big differences in oil temps, even at highway speeds.
My opinion is unchanged. There is no issue here on 30 grade for track cross.
  • Like
Reactions: GW.
My BMW ran around town 230-250 before I installed oil cooler. I was pushing 300f on track before oil cooler.
If you are concerned, dilute coolant with more distilled water and run heat at full blast at highest setting.
What I really want is an actual temp sensor. I've been looking at ways to add one, so I can stop guessing/questioning things.
I bet there is some aftermarket stuff. Did you check Mustang forums? Ask that question?
I agree. On track, regardless what event it is, you want oil temperature information.
But, in the meantime, I don’t think you have any issues. To @TiGeo point, he runs power dense engine on track without issues. I have same engine in Tiguan and it is oven under the hood.
Unless you are at high altitude, I wouldn’t worry and just kept having fun.
