I am replacing the u joints on my 2012 Colorado 3.7l. extended cab with 2 piece driveshaft which was made by Dana/Spicer.. According to the Spicer website, the u joint at the carrier bearing is suppose to be a 5-213X which comes with 4 external snap rings.
However, when removing the old u joints, the one in that area had 2 external snap rings and either c clips or nothing but the 4 8mm bolts and bearing straps similar to the 11mm bolts and bearing straps at the rear differential. It looks as though you could put two snap rings where there were none on the original carrier bearing u joint. Do I need to trade in the 5-213X for a 5-212X like the one at the rear differential. Is the Spicer site wrong?
