Coot Query, A/T in neutral at long stop lights
We always put our ATs in neutral at stoplights, etc. Never needed a rebuild, and have three over 200k miles and one just creeping up on 200k right now. I prefer the feel of sitting with the vehicle in neutral, rather than the driveline torqued and impeded at the brakes.
Daimler did a study a while back that determined that 30 seconds stopped was the minimum time that would yield a benefit if the engine was turned off... i.e. it takes roughly 30 seconds worth of fuel consumption at idle to equal that required for startup.
I recall they updated the figures for modern engines to 45 seconds.
UPS, a company VERY concerned about bottom line, has ther drivers turn off the engines at every stop. Is this because of bottom line effects of someone stealing the vehicle, or the wasted fuel vs. starter wear?
JMH
Neutral when stopped does save gas. My scan gauge has readouts in gallons or liters per hour, so at a dead stop in gear the gauge will read .4 gph when I move the shifter to N the gph drops down to .2 gph
Another example running with the AC on high and in gear .8 gph, so turning off some accessories at stoplights can save gas too.
