The coolant quick disconnect on the rear of the intake for my Chevy 350 began to leak a bit. So I decided to change it when I did my rad. I HATE coolant quick disconnects, and the factory aluminum hose was starting to show some corrosion damage (original part). This hose runs from the back of the engine to supply the heater cores (there are two on my truck).
So I made up my own fitting from brass hardware. The original part is 1/2" NPT, so I used a brass fitting with that threat and a nipple on the end where I used a worm gear hose clamp on a regular heater hose. The other end of the factory hose was already a rubber end with a hose clamp.
My only concern is the original connector had a restrictor inside, which appears to restrict the coolant flow. My new part doesn't have this restriction. Does anyone know why GM put a restriction in there? Will the higher flow cause any problems?
After I installed new part, I discovered that I can get a threaded nipple from GM that has the same restrictor in place. Do you think it’s worth the effort to change the fitting to the GM fitting?
