Group,
I recently had my timing belt, and water pump replaced. After replacing the parts, the repair shope used DexCool to replace my G-05 coolant. Well, the weather was warm today, and I decided to get the DexCrap out of my car. I also decided to replace radiator hoses. I got 2 gallons of Zerex G-05, 18 gallons of distilled water, and 1 bottle of RedLine Watter Wetter. I drained the DexCrap out...replaced it with ~ 2 gallons of the water. Let car warm up to normal operating temperature, with heat on. Drain, then repeat. I did this until the water came out clear...I also put in a bottle of Zerex Super Cleaner during the cycle of draining/filling.
Once I spent most of the day flushing....
I was ready to fill. Here is the mixture I used:
1.5 qts of G-05, 4 ozs. of Water Wetter, and 2.5 qts of Distilled Water to make a gallon of mix. I made up 4 gallons, put ~ 1.5 gallons in...I figured there was ~ .5 qts. of distilled water in the system. So my blend was: 37.5% G-05/62.5% Distilled H2O
Should allow the car to cool well, and be able not to freeze.
Any thoughts??
Any thoughts??
