Coolant Analysis: Prestone in 2002 WRX
This thread is getting more interesting than oil actually .
All the long life formulas I have seen indicate that they are silicate and phospate free but are dexcool compatible. I've also been hearing bad things about dexcool. There's something going on here!
It doesn't make sense. There are so many japanese cars, trucks and vans these days that domestic antifreeze makers MUST have an appropriate product available for use on these vehicles. There's a huge market and I doubt that most owners go back to the dealer to get antifreeze. Same story for neighborhood mechanics. Are the majority of import car owners putting in the wrong type of antifreeze?
Who supplies Toyotas Nissans and Hondas made in the USA and Canada with their antifreeze? Surely they don't import this stuff from Japan!
Can someone give us the skinny on the situation?
you guys got me all freaked out now.
on my mazda miata engine, i recently flushed the cooling system with bottled water and then drained and filled with a mix of regular prestone antifreeze and water. about a month later my waterpump went out. i changed the pump (which was a 33 hour hassle) and reused the old coolant as it was only a month old.
should i switch to some other brand of coolant? how does mazdas do for compatibility?
cryptokid, bottled water? you mean distilled water, right? if you mean bottled drinking water that could be worse than tap water. there's lots of minerals in there.
I'm a little bothered now because my manual never stated specific types of antifreeze. In another acura forum I first stumbled on this issue when owners started warning about the standard antifreeze causing pump seizure, throwing out the timing belt on interference engines. Ouch! How many miles on that old water pump?
it was only 63K miles on the pump.
the engine was made in 1996.
and by bottled water, i did infact mean just that, bottled drinking water. probably full of minerals. uhm, disani stuff i stole or uhm, borrowed from my girlfriend:P looking at a bottle of it now its says mineral enriched or somthing.
you think i should do a flush with distilled water and change to honda coolant? my owner manual says nothing about coolant except to use "ethelyene glycol compat with aluminum"
but it doesnt state anything about silacates or distilled water.
Each time you change a metal component in the cooling system (like the water pump), you HAVE to use NEW coolant, because old coolant (anything older than a few days) does not retain enough corrosion inhibitors to properly prime the new metal surfaces. And yes, I'd use only deminerialized (deionized)/distilled water.
ok, how about the type or brand of antifreeze? keep im mind i dont expierence temps below 45F even in the worst of winter (if you can call it that).
and i will go buy whatever is recomended tomorrow and do a flush the proper way this time.
I don't know about Mazdas. If you don't get an answer here and there is nothing specified in your manual, I would call your dealer's service department and ask them if it matters.
Sometimes you get good people at dealers parts dept, most times they take the safe answer and say yes we have mazda coolant. I spent 15 minutes on the phone with an Acura parts guys who did not know that they had upper contol arms!
Coolant, is used more for corrosion inhibition rather than increased boiling point. Increased boiling point comes mainly from the pressure in the cooling system. Furthermore the heat capacity of coolant is worse than water so coolant is less efficient than water in a cooling system. If you have hot weather and never go below freezing, I would not go more than 40% coolant. I'd go for less and change it more frequently.
Here's something I just found on the internet.
Dex-Cool vs. Green Antifreeze
As an engineer who designs waterpump seals for the OEMs (GM included), I feel the need to chime in on coolants. The traditonal green and Dex-cool are both basically just ethelyne glycol. The only difference between the two is the additives that are used to prevent metal corrosion. The green uses silicates which prevent corrosion by coating the inside of your engine. Dex cool uses OAT (Organic Acid Technology) to prevent corrosion. These additives do deplete over time. The main benefit of Dex cool is that it takes longer to deplete the corrosion protection. That's why it is sometimes referred to as long life coolant.
Green, silicated coolant is not normally abrasive. If the coolant boils, the silicates may come out of solution and create abrasives. The argument is that if you remove the silicates from the coolant, you will eliminate a failure mode of the seal. This is true. However the conditions that cause silicated coolant to become abrase, also cause other failure modes.
So green coolant is not bad for a car, as long as you maintain it. If your car came from the factory with Dex cool [1996 and up], keep using it. If your car came with green coolant, there is no real benefit to switching to Dex cool, except for a somewhat longer life. You will still have silicates in your engine because a system flush WILL NOT remove the silicates that have plated out on the inside of the engine.
I hope this makes sense, I tried to keep this brief. I could probably write a 10 page article on this if I didn't watch myself
Maybe that explains if you maintain your cooling system , you're ok. Just like oil!!!! Those fancy formulations are for lazy people and if not used carefully could be worse for you.
The color does not matter. They could make it hot pink so long as the spec.'s are right. You will probably be fine with any brand of silicate free coolant. Toyota has some that is very red in color and is silicate free long life, GM has Dexcool, Chrysler has HOAT wich is silacate free and green in color. I use Dexcool in just about everything and have never had a problem. I do not use distilled water any more. I live in the city so the water is pretty soft already. I turn my PUR water filter on and just fill up a jug with PUR filtered city water! If you are worried about Dexcool go to your local Toyota or Honda dealer and get a gallon of their long life coolant! I really have not seen any problems with dexcool. SO far I have used Dexcool in GM, Toyota and Daimler Chrysler products. I have one car that is 1997 and all origanal includeing the factor fill of Dexcool. It has 111,000 miles and the cooling system works fine so far. I am going to flush and refill before summer is over. I definately think that it is important to use a product that is free of silicates if that what your's requires but beyound that I do not think it matters much. I do not know enough to recommend mixing brands but if you are flushing it you should be ok with what ever brand you choose.
[ June 28, 2003, 11:49 PM: Message edited by: JohnBrowning ]
confused?
Here's more
A good rule of thumb is that most American cars, except GM, take the conventional green (or yellowish green) stuff. GM vehicles take the orange antifreeze/coolant with organic-acid technology (OAT). Honda owners should stick with the original equipment product that, though containing OAT, has a different chemical makeup.
In European vehicles, use a phosphate-free antifreeze/coolant or you may void the warranty.
Still confused?
The makers of Peak, based in Northbrook, tell us that GM specifies orange antifreeze/coolant with OAT but no phosphates or silicates. Ford specifies a yellow antifreeze/coolant with OAT and silicates. DaimlerChrysler specifies an orange coolant with OAT and silicates. VW-Audi specifies a pink antifreeze/coolant with OAT and silicates similar to DaimlerChrysler. Honda specifies a green antifreeze/coolant with OAT and phosphates but no silicates. Toyota specifies red antifreeze/coolant with OAT and phosphates but not silicates similar to Honda.
Originally posted by JohnBrowning:
...If you are worried about Dexcool go to your local Toyota or Honda dealer and get a gallon of their long life coolant! ...
You won't find a long life coolant at your Honda dealer. My manual says to change it at 35,000 miles.
Well, that depends. Looks like you spent quite a bit of time on that water pump and don't want to again right? If that is the case, I'd go for a non silicated one, but flush twice and rack up the mileage. Perfect time with warm weather and the Miata. Do not switchover in the late fall and put the car in storage for the winter.
As for myself, I'll need a new timing belt within the next year or so. I'm not hitting the mileage but the duration aspect. Even if I change the coolant now, I'll still change the water pump within a year, additionally, my car cannot rack up the 3,000 miles soon enough for me to be comfortable with the switchover. So all considered , I'm sticking with Prestone for the time being.
Originally posted by cangreylegend:
I also found out that the switchover to DEXCOOL or organic rust inhibitors is not as "smooth" as switching over. The silicates actually ( like oil additives) bond to the metals and do not flush off immediately.
Great post! It explains something that happened to me. I had the dealer chemically flush the system and switch my 1998 Tahoe from DexCool to the green antifreeze. After I had it back for a few days, I checked the level because sometimes it drops due to air working out of the system, etc., and I saw particles floating around in the overflow bottle. I pulled a sample from the radiator...same thing!
I called the Service Manager and he said that he was suprised because one of their best techs did the work. This may explain it. Maybe the system was flushed correctly, but some of the particles that were embedded in the system worked their way loose.
In any event, they flushed and refilled the system at no charge and the particles have never came back.
I stick with Toyota red and have never replaced a radiator or water pump in my 18 years of owning Yotas. I flush the system with distilled water and refill with the red and distilled.
Daily Drives
-2003 Toyota Tacoma PreRunner XtraCab, Impulse Red, Peppy 2.7 Liter 4 Banger, Running Mobil1 Synthetics SS 5w30.
ODO 3400 Miles.
-1995 Toyota 4-Runner, Evergreen, 3.0 V6, Running Mobil1 Synthetic SS 10w30.
ODO 76000 Miles.
That is why I think flushing, switching , driving, flushing and then refill is best. It is critically important to get all the silicates out because we have additive clashes going on here. Once you're silicate free, make sure no one puts silicate stuff in there again and don't go for the 100,000 miles claim.
That's my belief and am not an expert.
In reading through the bulletinsfrom honda, they do not mention that silicates will cause the pump to fail but it says that their coolant will lower service costs. They state that borates cause cylinder head pitting. I also note that CJH also if of the opinion that Honda water pumps last forever if run on silicate free formula. Honda also claims their coolant contains "organic" rust inhibitors which I suspect to be similar to the key ingredient in Dexcool which is also organically based.
So what's my story. In the late eighties, Honda was recommending timing belt changes at 60,000 miles. They did not specifically recommend changing the water pump as well but experienced owners knew that water pumps only last so long before they leak or seize. The route to the water pump in honda engines requires removal of the timing belt so many owners also replaced this as well.
In 1990, Honda out of the blue, recommended that timing belt changes could be extended to 90,000 miles. A whopping 50% increase same belt, same water pump. an issue comes up. My belief is that with silicate formulas, most water pumps have difficulties reaching that life easily if the cooling system is not well maintained. How many people religiously flush their systems every two years? I suspect a minority especially when their cars don't break down.
So what is significant about that? Owners were having water pump failures before timing belt changes or owners who had changed their timing belt and not change their pumps would have their pumps fail a short peruiod after their belt was changed. Timing belt removal and replacement is neither a quick nor inexpensive procedure for most japanese cars with their compact packaging. A soutce of custome dissatisfaction. Domestic engines, with their external water pumps present a different compromise.
Around this time, the organic rust inhibitors began appearing ( 1995) and was not widely deployed until 1996 by GM. So that made Honda's formula in 1994-1995 pretty much semi-exclusive.
If you look at the timing belt intervals recommended by Honda, they have been going up beyond 100,000 miles now. Nissan water pumps with many of their engines on chains, was also expensive to replace as well. Again the need for a high life pump. Toyota, I suspect face the same issues.
So for those with older Hondas who changed their coolants on a timely basis and their water pump at the time of timing belt changes, the silicate issue is not crucial. The issue of borate attacking the cylinder head was probably due to the silicates wearing out, which they do after a while, and thus not protecting the aluminum anymore.
I also found out that the switchover to DEXCOOL or organic rust inhibitors is not as "smooth" as switching over. The silicates actually ( like oil additives) bond to the metals and do not flush off immediately. In a switchover, you could get additive clashes leading to a situation and period where you get NO corrosion protection. How? in simplified form the silicate protect by covering the metal up with passive protection but the organic protection works by encouraging the metal to corrode to something that will then not corrode much more.(Rust converter like?) These actions are the opposite. So in a switchover, you MUST flush as best you possibly can and drive a lot to get that circulation going after switchover. In fact, I think it takes about 3,000 miles on a brand new engine before DEXCOOL or organic rust inhibitors to actually begin protecting. With engines that had been using silactes, it would take longer. However, silicates protect almost immediately. My suspecion is that in a switchover, it is best to flush, change to organic, and flush again and put in final refill and then drive a lot in a short period of time. Switching over is a risky thing for cars that are seldom used.
Another thing to note is that Honda does not state "long life" on their oragnic inhibitor. They probably know that while the organic rust inhibitor is longer life (35,000) it is unlikely to reliably last 100,000 or 150,000 miles.
DEXCOOL must be applied in a 50/50 mix. If used too diluted or concentrated, problems will occur. this is the same case for silicate formulas too but it appears to be more critical for DEXCOOL. That probably explains why Honda coolant is only available PREMIXED only. That way, they control the concentration. They recognize that many people pour the jug of coolant in and then top up with water leading to too concentrated mixes many times.
Another issue which comes up is that there is conflicting data regarding the "roughness" of silicates. I have found information that states that only when the silicated antifreeze is worn out, overboils or needs changing, then the silicates come out of solution and begin to be abrasive. this is unlikely to happen in well maintained cooling systems.
For me, since I currently don't put a lot of miles anymore on my 14 year old Legend, I am caught in between. I think I'll just maintain the pattern I've been on for 12 years and if my pump begins to leak before my timing belt changed is due, then I'll change both at the same time. However, after that, I'll just have to risk the crossover.
I apoogize for this long post but I'm sure it helps folks out.
Actually, my local dealership has both. I buy full strength and mix with Wallyworld distilled water 50/50.
I have Nissan coolant that I use in my Maxima and two Mazdas as well as Honda coolant which I use in the Accord. Both coolants are the same color. Both coolants state they contain no silicates or borate.
My '89 Accord Owner's Manual has nothing in regards to mileage or time for timing belt replacement. That is, there is no recommendation to change the timing belt.
Glad to hear silicates may only be a problem if coolant is neglected. Yearly, I drain, with the heater on, my coolant from the radiator and overflow tank, pour a gallon of distilled water through the radiator for a bit of a flush, close the drain valve and refill. This doesn't get all the old coolant out, but it keeps it fresh. Trick is to take care and get all the air out, it usually takes one or two heat up and cool down cycles to do this (though the Hondas have an air bleed screw which is nice).
[ June 30, 2003, 05:56 AM: Message edited by: ex_MGB ]
