All 5Wxx oils seem to be labeled as syn-blend now since API SP/ILSAC GF-6A went into effect, the 10Wxx and SP rated monogrades are still labeled conventional but are probably made with group II base stocks, which I guess you could call "semi-synthetic"I know from reading here that many so called conventional oils are actually semi-synthetic, to be able to meet the new specs, but I am wondering if ALL conventional oils are, specifically Supertech 5w30 and 10w30 high mileage.
Synthetic is bad vs conventional because?Unfortunately I think all of the 5W and below are synthetic blends now. Fortunately 10W and up is conventional.
I don’t feel it adds any benefit really plus my cars don’t get driven a lot and I change the oil every 3000 miles or 3 months. Except my moms car we do 5000 or 5 months because it has to have synthetic.Synthetic is bad vs conventional because?
Wait, so if you only get 500 miles on in three months you change the oil?I don’t feel it adds any benefit really plus my cars don’t get driven a lot and I change the oil every 3000 miles or 3 months. Except my moms car we do 5000 or 5 months because it has to have synthetic.
What does mom drive?I don’t feel it adds any benefit really plus my cars don’t get driven a lot and I change the oil every 3000 miles or 3 months. Except my moms car we do 5000 or 5 months because it has to have synthetic.
2017 CamryWhat does mom drive?
SN+ 5w30 and lighter had to be roughly 50% group III to meet spec unless it had the legendary Exxon Mobil mystery sauce base stocks. I would expect this to increase with SP.Most all conventional oils are group II. Group I conventional oils are rare these days in engine oils in the US and the oils that do contain group I are usually syn-blends with 15-30% group III to give it some thermal stability.
Given the price of synthetic oils these days, there's not much argument for sticking with conventional. The exception might be a drag racing engine spraying a lot of nitrous with low oil temps where the higher pressure-viscosity coefficient of conventional may be desired.
Some 5w30 and 10w-40 conventional oils may contain a small amount of group III if they want to reduce reliance on viscosity modifiers and allow them to more easily pass API tests. I wouldn't be concerned about it really. For just a few dollars more, I'd buy an oil that's all group III or higher.
I don’t feel synthetic is a better buy or anything. I have done the same things with conventional that I have with synthetic like cleaning a sludgy engine and stuff so I don’t feel the synthetic is worth the extra price. Based on what I have seen there is a price difference.Why "unfortunately"? They charge you the same either way. I also doubt many 10w30's and even 40's don't contain some GIII nowadays, since it has been stated that it is almost more economical for companies to meet specs and that they have a lot of GTL laying around (SOPUS at least)....
Stop wasting oil then.2017 Camry
I’m not lol. My dad won’t let that one go past 5 months or 5000 miles neither will I. We use Mobil 1 in that one.Stop wasting oil then.
