Thanks.OEM-type rubber control arm bushings don't need lubrication because they are pinched in place and twist, rather than rotate like a polyurethane bushing does. There's nothing to lube.
Exactly - Don’t tighten them with the car on the lift, tighten them with weight on the suspension, or you’ll ruin them in very short order.And to add, as you probably already know if they aren't installed unloaded then they will fail more quickly. Does the maintenance manual give you a ride height prior to tightening? It depends on the exact design and which bolts, but my BMW control arms had a loaded height for the body bolt.
Can I use a jack to lift the wheel up when installing bushings ?Exactly - Don’t tighten them with the car on the lift, tighten them with weight on the suspension, or you’ll ruin them in very short order.
They’re designed to flex +/- from installed position, neutral suspension, not get cranked all the way around from unloaded to fully compressed.
That would not be my first choice, but that is the idea - full weight of the car on the control arm so that the bushing is in the proper position. A rack is better, with the car level.Can I use a jack to lift the wheel up when installing bushings ?
I have quick jack lift system so it MUCH sturdier than a jack.That would not be my first choice, but that is the idea - full weight of the car on the control arm so that the bushing is in the proper position. A rack is better, with the car level.
I leave the bolt finger tight, drive the car up on ramps, jack up the back so that it is level, and then tighten it to spec.
I would not get under a car held up by a jack.
That's what I do, seems to get it close enough, I lift until its "about" the same angle as sitting on 4 wheels, or that side gets light on the jack stand.Can I use a jack to lift the wheel up when installing bushings ?
Measure the center of the wheel to the fender. After installing, lift the tire to that position and tighten it. It is is the second best option, after one @Astro14 mentioned.Can I use a jack to lift the wheel up when installing bushings ?
I hate changing these out on my MK4 2003 Golf TDI or on any car for that matter.
I just changed them out. Is there any lubricant that I can use to make them last longer?
Thanks.
Those are supposed to remain dry. An occasional silicone based lubricant won't hurt.I hate changing these out on my MK4 2003 Golf TDI or on any car for that matter.
Thanks.
Some of us dont like to telegraph the road surface to our kidneys at speed.
There’s no lab test required.This would require a lab test but so far the bittoggers are convinced that it’s best to tighten the bolts with the suspension in the loaded position. The ends of the bushing are pinched against the metal structure on each side of the bushing. Now imagine the upper and lower arms moving up and down many times per second with an incredible amount of force as the vehicle drives over bumps in the road. Think the bushing might spin the slightest amount to find it’s own new neutral position?
