Was a bit surprised by a few of them .
https://www.consumerreports.org/tir...tires-can-save-you-money-at-pump-a1547901110/
Industry studies show that a 10 percent drop in rolling resistance equates to about a 1 percent improvement in fuel economy. Over 12,000 miles driven, that 34 percent difference in resistance equals about 14 gallons of gas separating the best performer from the worst, based on average fuel economy. It adds up to about $70 per year, or about $360 over the life of a set of tires (62,000 miles for a performance all-season tire, based on CR testing). We based our savings calculation on gas at $5 per gallon.
Tire rack had a test a few years ago. The Michelin Energy Saver got about 7% better than the GY Comfort Tread. Check out the test, pay your money, and take your choice.5-10 mpg difference on first gen Honda Insights using the original Bridgestone Potenza tires vs. conventional models, but after 30,000 miles they are worn out and not exactly cheap to replace. The numbers don't always make sense when regular tires are half the cost, but if maximizing mpg numbers is your thing, you buy them anyway.
Pretty sure that if CR tested these tires on a dynamometer, they would have had the forethought to make sure the air pressure was correct.I'm surprised that they didn't include in the article, a brief mention that proper tire inflation also reduces rolling resistance, and thus safes fuel, thus saves money.
I'm not doubting CR testing discipline. I am saying that they should have taken the opportunity to remind their subscribers that saving fuel can be as simple as maintaining proper air pressure in their tires.Pretty sure that if CR tested these tires on a dynamometer, they would have had the forethought to make sure the air pressure was correct.
Maybe I misunderstand your post though, since proper inflation has a significant impact on rolling resistance.
I am disappointed by the article by not noting if any of these "top selections" are run flat tires.
My question is, is there a run flat that also has low rolling resistance? Or where how do they compare to the top choices.
