Considering a Toro ZTR. They seem to have a few different grades. Frome the basic up to the Titan. Probably going with a 50" for just under $4000.
Opinions?
Opinions?
Send you a PM if you're interested.Considering a Toro ZTR. They seem to have a few different grades. Frome the basic up to the Titan. Probably going with a 50" for just under $4000.
Opinions?
I keep seeing the Bad Boy brand show up more often. I always liked the ventrac mowers but don't know if the offer zero turn.Considering a Toro ZTR. They seem to have a few different grades. Frome the basic up to the Titan. Probably going with a 50" for just under $4000.
Opinions?
It would be worth your time to check out the ZT offerings from Ariens with the Kawasaki engines if the dealer service network is available in your area.
52" Ariens IKON Zero Turn
Bad Boy sells factory-direct to dealers. Cutting out the middleman / distributor likely saves them (and potentially the consumer) a few bucks. I think they make a good productI keep seeing the Bad Boy brand show up more often. I always liked the ventrac mowers but don't know if the offer zero turn.
I've sold & serviced Toro and they are good machine for the money ... BUT I've found parts prices are often high compared to Deere. Personally I would consider Deere but in your area Toro might make more sense based on the dealers.Considering a Toro ZTR. They seem to have a few different grades. Frome the basic up to the Titan. Probably going with a 50" for just under $4000.
Opinions?
For that price, that sounds like a consumer-grade model from a big-box store. Yeah ? If it is, I'd suggest going to an actual Toro dealer, one that also services them, as they tend to sell 'better' grades that the big-box stores don't have access to. Will likely cost more though.Considering a Toro ZTR. They seem to have a few different grades. Frome the basic up to the Titan. Probably going with a 50" for just under $4000.
