My wife's car (2000 Cavalier) still has the factory fill of DEX-COOL. No problems. I ran Havoline DEX-COOL in my 1996 Accord for three years after a thorough tap water (didn't know any better at the time) flush of the old juice. No problems. I recently thoroughly flushed with distilled water and refilled my aluminum V6 2003 Sonata with the 50/50 SuperTech extended life juice and distilled water. Three months, and all's running cool and clear. All this may be only word-of-mouth anecdotal for
you, but it counts a LOT for
me. Air is the bugaboo of any corrosion inhibitor chemistry - perhaps more so in the absence of phosphates and/or silicates. DEX-COOL lacks both. Japanese antifreeze formulations have a stiff dose of phosphates but no silicates. G-05 has NO phosphates but does contain silicates (at reduced levels) and carboxylates (organic acids). Both approaches work. But, so does DEX-COOL when the system is well sealed and the proper pre-installation prep work has been thoughtfully undertaken. But, theoretically, the ideal would be NO phophates or silicates in order to maximize water pump life. GM has some well-documented gasket problems on the cylinder heads and intake manifolds of certain engines, and additionally went through a period of equipping its cars and light trucks with poorly designed/made pressure caps. Chrysler and Ford's position about alleged gasket material incompatibility is also well-documented, but frankly, a little specious to my mind. Ford states flat out NOT to use "orange" antifreeze in their current models (complete with stick-on label under the hood). Yet their recommended antifreeze (essentially G-05) has carboxylate technology just as DEX-COOL does, but with the addition of some silicate content. What gives? Either carboxylates are evil or they're not. Ford seems to be trying to have it both ways - "Don't use carboxylate-ridden DEX-COOL, but you CAN use
our carboxylate-ridden juice." From a brief perusal of a 2002 Neon owner's manual, Chrysler takes the same attitude - but their G-05
is dyed orange. (Hmmm... would that indicate that MOPAR antifreeze/coolant would be incompatible in Fords? (
) Oh, and before someone quotes chapter and verse from that "
Motor Magazine" article by Paul Weissler that 2-EHA is a dreaded seal damaging
plasticizer
), I did some online research and posted my finidngs in
this thread. It turns out that ALL carbolylates used as antifreeze corrosion inhibitors are used as components in
making plasticizers. (They're also used in food preservation and pharmaceuticals.) That includes the sodium benzoate that Peak and Zerex use in their respective extended life products - and that, in turn, includes G-05. (
) So, am I saying that NO antifreeze/coolant product is safe? Nope - just pointing out that ANY of 'em'll work in a sound system if you do your homework before glugging the stuff into it. And, I believe the inverse is also true - if your system is compromised, sooner or later you'll have some serious problems regardless which technology you choose.
[ November 17, 2004, 02:59 PM: Message edited by: Ray H ]
