JHZR2
Staff member
I an contemplating putting in something like an 8x2.5' concrete pad. Something to hold two split AC condensers side by side perhaps.
I've never done concrete work but imagine this may be too small a job for many pros.
We are contemplating redoing our driveway in an aggregate, but I don't think the time frames line up with when we want the pad.
Any good tips? I want it to more or less be like a sidewalk but raised 1-2" from the nearby soil. I would frame it with 2x4s and then pour into the area, possibly over rebar which I guess is overkill, but if I'm DIY, labor is free so why not?
What about concrete? Is quickrete or similar from the stores mixed in a bucket or rental mixer really the same as if I got some from a real concrete truck?
Can you get a really small batch, like at the end of the day, or end of their run?
Not to be cheap or do lousy work, but could one make a pad from cinderblocks if the ground they would be placed into was perfectly flat?
I don't mind pourin a few smaller, independent pads immediately nex to each other if it would prevent cracking. Is this advisable?
Thanks!
Thanks!
