I hope this is permitted if not mods can delete thank you. Is this a true video that the computer Computer knows what kind of oil was used?
Often a key point that’s ignored. People think the viscosity of a grade applies to every temperature.P1521 incorrect oil type. There’s a TSB to reprogram the PCM to address this issue. The system was too sensitive and the code would trip during hot oil conditions(to little oil pressure). The only input is the oil pressure sensor. So no the engine is not actually viscosity sensitive.
Cute. Rename the oil pressure light.P1521 incorrect oil type. There’s a TSB to reprogram the PCM to address this issue. The system was too sensitive and the code would trip during hot oil conditions(to little oil pressure). The only input is the oil pressure sensor. So no the engine is not actually viscosity sensitive.
Probably one of the most misunderstood concepts here for some reason…Often a key point that’s ignored. People think the viscosity of a grade applies to every temperature.
Do those same people not understand the saying "as slow as molasses in January"?Probably one of the most misunderstood concepts here for some reason…
For what you spent on that van, none?I’ve always wanted a car with a dynamic viscometer
There’s an app for that!For what you spent on that van, none?
