I don't think it is related but I am just wondering. This is on a 1999 Camry 2.2L 4-cyl engine. When the A/C is turned on, compressor tries move a little but ECM immediately shuts it down. There is a sensor on the compressor which tells the ECM if the compressor is spinning or not.
Is there any chance that only the clutch is burned out and the compressor itself is fine?
To the best of my knowledge, the compressor does not need to come out for the timing belt job on this car. Only the serpentine belt. Belt is tight; may be too tight? But could tight belt cause this problem?
I think it is just a bad coincidence that after the timing belt job.
