- Joined
- Mar 19, 2022
- Messages
- 697
Just wanted to give some somewhat scientific evidence that JD CGII works.
I dumped the 2 year old green/distilled water 50/50 mix of IAT (also had a bottle of Rislone Hy-Per cool). Flushed system with hot domestic water....many gallons, removed thermostat etc.
Blew everything out with compressed air in all directions.
Poured in JD coolant (4.8 gallons) from the 2.5gal premix (all the JD dealer had) and put in a bottle of Rislone Hy-Per cool...don't know if it does anything, nothing to loose.
I have a 2 stage electric cooling fan controller. It never even comes on stage 1, same outdoor temps, same everything else. Cooling system always seemed saturated, and/or lack of airflow before. Now with no changes, the temp never gets up to the 200 to turn on the 1st stage cooling fans, other than completly stagnant in town. Would always stay on 1st stage under 30mph, and would go to 2nd (210F) in town, stop and go.
Same thermostat, which was tested 3 years ago, no cooling or timing changes other than the coolant.
