I'm working on a '53 Farmall Super M. The trans and rear share oil in the case. I would like to use 80w-90 or 85w-140 GL-5 due to ease of availability and cost. Some (not at BITOG) have suggested that the EP additives in the GL-5 might cause pitting in low unit loaded spur gears such as would be found in said tractor.
I imagine they are thinking of issues between GL-5 and brass, but I wanted to ask to make sure I haven't missed something. There is no brass in the tractor rear or trans, only ball bearings, spur gears and one bevel gear set. I have another M that I put 80w-90 GL-5 in about 5 years ago, but I haven't had it apart to look for any damage. It certainly hasn't failed.
Manual calls for 90w. I don't know when they started the GL ratings, but I don't know if the original fill would be as good as GL-1. I'm sure GL-5 is overkill, but is easy for me to find and budget friendly. Also I can keep one kind of gear oil in the shop.
I appreciate any info or suggestions.
