Been using a mos2 additive regularly for the last 40k miles on account of some better used oil analysis and, well, I'm the guy that splits hairs like that.
Dropped my pan down to do some maintenance and I found this rather thick sludgy stuff at the bottom of the pan. Not a lot, maybe a couple teaspoons worth in total. But it's there, hiding in the corners at the bottom. Did some inspecting on it since my engine has an exceedingly good service history and igbdfwiswe has no sludge or anything beyond a light varnisn, and found it to resemble the Mos2 additive I've been using. The stuff looked and felt like a thin grease.
I've not experienced any clogged filters or other concerns, and based on the amount, I think most of it stayed in suspension. But a little bit from each OCI seems to have settled out in the pan and formed a layer of gunk that just wouldn't agitate and suspend even after a 5 hour road trip.
If I was thinking ahead I would have taken come pictures. That bit only occurred to me after the fact.
Not going to name brands here as its really not my goal. Consider this more of a PSA, where something that might be good in the short term, or even mid term, isn't great long term. I reckon if I would have continued use to 150k miles or so I might run into issues with plugging the pickup screen.
Edit: I should add this vehicle isn't driven daily. It's used 1 to 3 times a week
