The coil pack on my explorer (used pretty much from 90-11 on every v6) has serious cracks and rust jacking at the base.
Truck runs well, maybe it could be a bit better in some instances, but hard to justify the 42 $ to replace it for a motorcraft part(online price).
Has recent plugs and wires.
Seems that the taurus coil packs cause problems even with a tiny hairline crack, but these sort of don't from internet searches.
I could run a mode $06 to see if there are some misfires, but no codes were ever set.
Is it it a good idea to replace a coil just because the plastic is cracked but otherwise asymptomatic?
My truck was state inspected at the dealer, and the tech that did it said if it was his he would change it immediately. Dealer quote was 165 on the work order. His reasoning was that on very damp day it will short out and you will be driving around dumping gas in the converter from two cylinders. He said it can take the wire and plug out too.
