I was looking for a 75w-90 gear oil to do a flush on my '96 Subaru Outback before swtiching to synthetic. Now, normally I would just switch but this transmission had recently been split apart for a re-seal. Subaru manual transmissions have a center differential inside the transmission case and the transmission and differential share oil, so I thought a GL-5 was required.
The only two 75w-90 oils I could find were Coastal which is rated GL-3, 4, and 5. The other was Castrol Hypoy-C which is rated only GL-5.
The Castrol bottle stated it was for "service fill" of limited-slip differentials. The Coastal stated it was only to be used for top offs of limited-slips. This is a significant issue, as if the oil has friction modifiers for a limited-slip, the syncros don't like it.
I chose the Coastal oil, but the wording of the Castrol bottle left me wondering. Does "service fill" in Castrolese mean drain and refill with no friction modifier needed, or just top offs?
