Originally Posted By: GTO52
I got 2 professional opinions today, both said its the input shaft bearing, the guy that's going to the job is actually guru on Toyota pickups and has done quite a few of these transmissions with exactly the same problem but usually ones with a higher mileage than mine.
Definitely get the I.S.B. replaced ASAP. If the bearing falls apart, the spherical/metallic balls inside can fall out into the transmissions gears.
If your clutch is good you may just be out a good amount on labor, but better than having to shop around for a rebuilt trans at 5x the cost of this job to replace the ISB, easy.
