Clunk in Front End Driver Side- 97 Toy Avalon
Brooklyn, NY
I had been hearing a clunk every now and then on the drivers side when going over bumps that dip, such as potholes, where the suspension unloads then loads again. I went up on the sidewalk a few days ago and came down, not hard or anything it wasnt an accident, and after I noticed the sound got much worse. Today I replaced the front sway bar bushings and end links (they were shot anyway) but it didnt fix the problem. The strut mounts were replaced about 7 years ago. Ball joints are a few weeks old, so I doubt those are the problem. The tie rods are original, as are the struts and subframe bushings. Any ideas?
Maybe struts, strut mounts. I know the bushings and end links wear out in those cars but you've already replaced them.
Im pretty sure I have narrowed it down to the strut mount, as the clunking i hear is coming from the upper part of the car. Oh well too involved for me, I'll just leave it for the time being
Strut mounts without any doubt whatsoever. Not a hard job actually, a couple of hours if you take a time. Rent a spring compressor from AutoZone and get on it :D
Let's assume the strut bearing is good. How does a strut mount go bad? What wears out? Seems like it isn't a moving part per se, the strut bearing handles rotation for steering. Does the plastic of the strut mount deform from stress? Any rubber bushings in there?
Just curious.
