have had my 1988 Escort XR3i Cabrio for just over a year now.
The previous owner/s neglected the cooling system badly, it had no trace of coolant in the cooling system, just brown rusty water when i bought it.
I have by now flushed the coolant about 5 times ( just drain and fill )
Before, the fresh coolant would turn brown again shortly after changing it because of the rust.
Now the coolant stays clean, however i have to clean out the expansion tank every few months because it keeps accumulating rust at the bottom, i changed one of the hoses in December and found the inside of the old hose, and the inside of the thermostat housing still completely caked in rust ( cast iron block, Alu cylinder head )
Despite all this the engine has no cooling problems, leaks or anything else, it's just really rusty inside.
What generic type of product would you recommend to clean out the rust?
I live in Spain so it's pointless to recommend a particular brand or product, because i won't be able to get it here.
Vinegar?
Citric Acid?
De-scaler??
2019-03-01_10-18-11 by Argentum Enim in Sempiternum, en Flickr
Vinegar?
Citric Acid?
De-scaler??
