Owen Lucas
$100 Site Donor 2023
- Joined
- Sep 5, 2021
- Messages
- 4,991
I'm changing out the fluid in my power steering system (2005 Scion tC, i.e. Toyota Camry) and would like to clean up the dirty reservoir while the fluid is out. I'll remove it from the engine bay for easier access to remove dirt and what appears to be staining in the plastic.
Should I soak the whole reservoir in a bucket of soapy water or fill it with simple green after closing off the ports? What cleaning method do you recommend?
P.S. The power steering fluid is Dexron 2 or 3 ATF.
