I use a suction gun for filling up manual transmissions, differentials, etc. that have the fill hole on the side where you can't easily pour a bottle into. It looks kinda like a grease gun, it has a tube coming out of one end (where you suck up, and then dispense the fluid from) and on the other end is a plunger you pull to fill the gun, then push in to dispense the fluid.
I want to to know what's the best way to clean this thing out in between uses. I don't want my transmission fluid to become contaminated with left-over gear oil and vice versa. Hose it out with a can of brake-clean maybe? How about cleaning the hose itself? It's actually part of the gun, so I can't just buy a roll of tubing and throw it away as I use it. And I would think the brake-clean would eat away at it, seeing as how it's some sort of rubber. Any suggestions?
