CJ-4 / CI-4+, Comparison???
Phoenix, AZ.
I thought I had read that the new CJ-4 was NOT as robust an oil as the older CI-4+, was.
Anyone know, for sure, if that is true, or not?
I was just wondering if it would be a good idea to stock-up on the CI-4+, while it's still available. Like everyone else, I'd like to run the best, strongest oil, possible.
Thanks for your feedback.
Joe Fihn
If you run a conventional 10w30/15w-40, the basestocks and additive pack of CJ-4 is superior to CI-4+ in terms of wear, deposits, oil consumption, soot dispersancy and oxidation resistance. The only drawback I see to CJ-4 is that to meet the sulfated ash limit of 1.0%, they have had to reduce the levels of alkaline detergents by about 1/3. So these will be 8-9 TBN oils instead of 11-12 TBN oils. In addition, the price of CJ-4 oils will be about 15%-20% higher....
The combination of CJ-4 + ULSD fuel should result in OCI's that are comparable to CI-4+ and 500 ppm fuel. The CJ-4 engine sequence tests are run with both ULSD and 500 ppm sulfur fuels, depending on the particular test. Lubrizol has a nice summation of the slate of tests on their website.
I've spend quite a bit of time studying CJ-4 and talking to the Amsoil Tech services guys, and think it will be an exceptional product - particularly for mixed fleet use.
TS
Joe - this matches with what you wrote here:
http://theoildrop.server101.com/forums/s...ge=0#Post729362
And is an excellent question. TS provides an EXCELLENT answer. The new CJ-4 oils may not be the perfect fit with super long OCI's, using older diesel fuel in an older diesel engine. However this is easily mitigated by cutting back on the OCI. The trade off on the good side are better, cleaner diesel engines and a modern HDEO to fit.
Pabs, what TS says re TBN and OCI's I think is borne out by our results here with ULSD and CI-4 oils where the TBN barely moves over the 20,000km I've been using. The last two test results from the lab I use here in an indirect injection turbo Nissan resulted in TBN's of 12.9 and 12.6 respectively with D1 after 20,000km.
Of course the 100,000km operators in the big rigs may find a difference.
My understanding is the CJ-4 oil and running ULSD in a 2007 or newer diesel engine will produce really good results as well as long OCI's. The whole point to the new oil from my understanding in the 07 and newer diesels is to keep the particulant level down so that the particulant filter that is going to be on all newer model diesels doesn't clog as fast. It is suppose to have a 150k life rating. The whole fuel system as well as the oil system work in harmoney with each other all to keep emissions down since they will all have an EGR valve on them as well. AMSOIL did a really good job at explaining it at the Falls Sales Meeting I went to in Richmond last month.
Joseph,
Just as a matter of interest, which CI-4 Plus product are you using?
What I really do not like about the CJ-4 thing is the phosphorus content of max 1200 ppm, A slight reduction compared to the 1200 - 1300 ppm in CI-4+ oils.
Also, according to Chevron and Lubrizol, there is even a phosphorus limit for CI-4 oils of 1400 ppm, whereas Mobil says the typical level is 1200 – 1600 ppm. Is that true?
http://www.delobike.com/Chev CJ4 Q_A.pdf
http://www.lubrizol.com/CJ-4/faq.asp
http://www.mobil.com/USA-English/Lubes/Files/Delvc_PC-10_FAQs.pdf
As for sulfur: max 4000 ppm. Do we know how much sulfur there is in today's Delo, Delvac, Rotella etc.?
And sulfated Ash: max 1.0%. Ok, Castrol makes Hypuron S CI-4 with 1.1% ash and a TBN of 14.1, so it does not seem impossible to make an 1%Ash/TBN 12 oil. But, yes, I know the virgin oil TBN is not that important. ULSD will help a lot too.
Now the part that makes me angry: The Noack volatility is still allowed to be as high as 13%. It is like any synthetic CI-4 oil can do it better. Maybe some of the new additives required to meet the P, S and ash limit tend to be more volatile than the traditional ones, I do not know. The CJ-4 engine tests include a lot of piston deposit evaluation, but where are the rigorous real would oil consumption and DPF plugging tests? I do not know if I understand it right that the 500 hour long Cat C13 allows an oil consumption of 31 g/hr? That sounds to be much. Is this C13 modified to elevate the oil consumption for test purpose?
I remember Doug Hillary said that his 500 hp Detroit series 60’s average oil consumption is 1 litre every 6000 km with Delvac 1. If we say that 80 km (50 miles) are equivalent to 1 engine hour, he uses 1 litre (854 gram) pr. 75 hours => Less than 12 g/hr. Also, this is the average consumption for his long drain intervals of 60K miles or so.
PC-10 would have been a good opportunity for the engine manufacturers to recognize the advantages of synthetic oils (maybe group 3 also), even without chemical regulations. Not to approve oils because they do not meet those chemical limits looks a little like “cubical engineering” to me, I am sorry.
Would all CI-4+ oils fail the engine tests?
We all know, that engine tests (API and ILSAC) are getting stricter and chemical regulations will require more new additives in the future. The result is, that it is getting more and more difficult to make low-cost formulations to meet the current >minimum< requirements. But, what about the "premium" products that have been using some kind of "state-of-art" technology for years. Some of them may have exceeded most requirements for years. Now the chemical limits will force the manufacturers to change their proven chemistry. The new chemistry may perform less good in some disciplines. Thinking of today's HDEOs, I just find it interesting, that Cummins thinks there is a need to measure valve train wear in ISB engines these days. How long time has the sliding cam tappet B-series been in the marketplace, almost 20 years, right? Do we know about valve train wear issues with B or ISB engines, using Delo, Delvac, Rotella, Schaeffer's 7000, Pennzoil LL, Valvoline PB and other premium HDEOs? :shrug: Ok, we may see higher cam pressures in new eingines.
All in all, making a good engine oil is more than just making a mixture of different traditional and nontraditional additives at a radio that looks nice to people who like “older” oils. But what I want to say is that if there were no chemical limits for CJ-4, formulators would not push the phosphorus content below the 1200 ppm. I am glad that we have people like MolaKule to inform about changes in additive technology. He helps me understand that cutting down something is not so bad if it is substituted with something advanced.
If we look at “engine wear”, there may be a “different kinds of wear”. I mean wear caused by high loads/pressure and engine “typical” wear increased by combustion by-products and heat, corrosive wear, as well as wear depending on engine operation and duty cycle. If it was about load carrying ability only, we could probably use an EP gear oil in our engines. Finally, only long-term real world test will show how CJ-4 will perform. BTW, will CJ-4 oil meet Allison C4?
What I use to say is that we should not buy things because the industry wants us to. New is not allways better. DPF plugging concerns do not bother me yet. My parents mid-90’s CDC-Cummins engines have been lubricated with “normal” oils their entire life, currently with Delvac 1 CI-4 Plus. Also, why pay more to get the same, or maybe less?
I like the fact that Amsoil has not just reformulated their AME and HDD.
ED.
IMO, if there is a particular oil that you like a lot, and you can get it for a good price, it would not be a mistake to stock up.
It's not a matter of buying a CI-4 Plus oil before it gets reformulated into a CJ-4 oil -- most of the major companies will continue to offer both products. Fleet operators are going to be very cautious, and will not want to suddenly make a 100% switch to CJ-4. It would be stupid for a motor oil manufacturer to abandon loyal customers -- let the customers decide when they are ready for CJ-4.
Motor oil is not going to get cheaper, so if you find a deal, stock up.
talked to mobil twice now they said" the new cj-4 oils will be a vast improvement over ci-4 and not to worry about lack of protection they are using other substances to add to the oil"....take this for what it's worth.this was in regards to delvac 1 5w-40 that i use
As far as I'm concerned for our part of the world, CJ-4 will be a long time coming. The government standard sulfur in diesel fuel, which is rarely met, is 2000 ppm. I've seen some lab reports with 15000 ppm, although more common is 5000 ppm.
But we don't have any new trucks, nor do we have any catalytic converters.
+1
I agree. Cleaner fuel will be a big plus in OCI.
I think one erea that is being overlooked is how well the CJ-4 is going to work in gas applications. This stuff had to meet some tough specs in the realm of heat resistance,valvetrain wear and oxidation. This oil may be capable of outperforming full synthetics of a mich higher price range without the fear of catalyst damage.
The line that separates conventional and synthetics will be non-existant in a few more years.
